HomePortalFAQSearchUsergroupsRegisterLog in
Join the fight against the Gobi in the Land of Graves
 Treeline Stairwell (Upper)
Go down
Xander
PostSubject: Treeline Stairwell (Upper)   10th December 2014, 11:47 pm
Name: Treeline Stairwell (Upper)
Description: This is a unique oddity as a cluster of trees in the Land of Echoes have been aligned like a spiral staircase winding around each other with the center being occupied by the largest tree in the forest stretching so high into the sky that it is rumored to touch the clouds. What is up there one will never know. The upper layer is home to the second shortest trees out of the cluster, each typically being 1500-2000ft high & having trunk diameters of 150-200ft (at base). All of the wood of comprising the trees of Treeline Stairwell secrete sap which makes them fire resistant and the wood itself is chakra resistant with the older a tree is the more resistant to chakra it is (older trees of this type are always the tallest).
Chakra Consumed to Stick to each Post (Total) - Height of Tree
D - Base to 500ft
C - 501 to 1000ft
B - 1,001 to 1,500ft
A - 1,501 to Canopy
Exact Location within Area North
Current Places Within
Denkou Ancestral Grounds (Red Entrance):
Overall Income Generated
Overall Upkeep
"I've grown disillusioned with the idea of a shinobi, innumerable amounts of them are seen running around throwing around flashy ninjutsu and have lost sight of what it truly means to be a true assassin. Perhaps I'll be the one to shatter that illusion, and reeducate the populace on what it really means...to be called, Shinobi."
Back to top
» Sword of the Thunder God Plot (Yang Group) [Upper, Treeline Stairwell]
» Sword of the Thunder God Plot (Yin Group) [Lower, Treeline Stairwell]
» Summertime. (Open to All)
» Sendo Ketsueki (The Blood Red Crow of the Mist) - B Rank Nukenin ~WIP~
» [Krag Climb - Upper]
Naruto Beginnings :: Origin Continent (Land of Beginnings) :: Neutral Territories :: Treeline Stairwell-
